saltyfries
Thread starter- Joined
- May 11, 2009
- 27
I bought a 14' Lund with a 1969 Merc 75 (7.5 HP) a couple of weeks ago. Engine serial is 2534336 which makes it a 1969 according to my research. The owner said it would need a "tune-up" and so far, except for some leaky oil seals in the gearbox, I guess everything I have found falls into that category. I've ordered a new impeller, oil seals, fuel pump re-build kit, plugs, and a tune-up kit. I'm starting with replacing the points and condensers and will post pictures as I go so if you see anything wrong with the way I'm doing things please let me know.
Starting with the manual starter, I removed the large top nut. I discovered that this nut has a left hand thread. Then, I removed the three phillips screws which hold the starter to the engine block and removed the starter.
Next, I improvised a pulley puller from a steel disk and some nuts and bolts (picture attached). Using a rectangular bar and a wrench, I removed the flywheel RH nut from the flywheel. Then, using the puller I applied pressure until I felt a sharp pop. I removed the puller, removed the flywheel, and discovered that the shaft is tapered in addition to being keyed.
More to come...
More to come...
