Newbie needing help with 1990 Johnson 60hp
bullfrog_jwa
Ok, so I'd like to start out by saying that my current boat is the first that I have ever tried to work on personally. I have a background in auto and industrial maintenance, but I have never ventured into the world of outboards before. I acquired my current boat once my dad died a few years ago. It's a 1973 Chaparral tri-hull with a 1990 Johnson 60hp VRO. I do know the VRO has been bypassed. When I got the boat, they had lost the key...so I replaced the ignition switch. When I tried starting the motor, it would spin over, but got no fire. The boat has been sitting for about 3 years and I have decided to try and fix it because of who it belonged to. I bought a new fuel tank, new gas, and new fuel line that runs from tank to motor. I also bought a brand new battery for it. Tried to crank it up and found I wasnt getting fire. I was talking to a buddy of mine who "had been dealing with boats for awhile" and he told me to unhook the big red plug and jump the starter and see if I get fire. He informed me that if I did get fire, the power pack was bad. Going off this advice, I did as instructed and got fire. I ordered a brand new power pack, installed it, and still had no fire. After searching forums, I found a thread for bypassing the kill switch circuit. I disconnected the black wire with yellow stripe for the kill switch and started getting fire. The motor would spin over, but wouldnt actually fire over. I disconnected the big red plug again and jumped the starter and it ran for 30 seconds or so before finally choking out. I hooked the big red plug back up and tried to fire the motor up again. I got spark (I was using an inline spark tester) but could not get the motor to fire over...not even using starting fluid.
As I am new to this whole thing, any ideas where I should go from here? Any help at all would be greatly appreciated. Thanks
interalian
Did you get the correct ignition switch? Disconnecting the red plug isloates the kill circuit and MOB (man overboard) switch. Could be the MOB switch lanyard is missing?
bullfrog_jwa
Im pretty sure its the right ignition switch. I took the old one to the local boat dealer and they matched it up. Also, the MOB lanyard is still attached to the control box.
Your " buddy " gave you the wrong informatiom--Getting spark with the red plug OPEN indicates nothing wrong with or on the motor.-----The problem is with the boat side control box , wiring harness or your new key switch.--I would double check the wires on the new switch.----Hopefully 12 volts was not applied to your new powerpack.-----Note---Powerpacks are often replaced for no reason since they are a bit of a mystery----Not expensive and you now have a good spare I think..
