Hi all, I have a 1974 Jolly Roger with a 140 Merc in major need of some help with the gelcoat (I think!?!). The gelcoat has been abused by the sun now for 30 years and also by many encounters with the dock. Here's a picture of the condition of the gelcoat on the top half of the boat. <br />
<br />You can obviously see the clear coat that is blistering and flaking off. At other points in this coating, there are small cracks, both straight and spider. At some point in its life, a new clear coat was applied to the boat, which is the coating that I assume is now flaking off. <br />
<br />This is a picture of the hull, the gelcoat is in much better condition minus the gouges in the sides that have gone through to the fiberglass. They look white because they're filled with wax. <br /><br />Basically, I'm looking for an assesment of the damage and any ideas on where to get started on repairing the gelcoat and the deeper gouges in the fiberglass. I'm learning a lot reading the other posts on gelcoat repair, although I haven't seen much with the extent of damage on my boat. I would like to keep the purple metalflake if at all possible. Thanks a lot in advance for your help.<br /><br />Pat
