Newbie Battery Question
tengals123
Master Chief Petty Officer
I have a 69' merc 100. With the starter battery, what do i have to do to maintain it. ie. does it charge itself, like a car batt. or do i need to buy an external charger. If so how often do i need to charge it? thanks
WillyBWright
Re: Newbie Battery Question
That will have a charging circuit in it, but not a very strong one. People (like waterskiers) that do a lot of short distance runs with alot of starting and stopping often find that they need to suppliment the charging with a charger before and/or after use.<br /><br />You should check to see if it is charging your battery. If you connect a voltmeter to the battery, you should see voltage rise as RPMs increase. That motor won't have a regulator on it, but it will have a rectifier. If that goes bad, you won't charge. Other things could cause a no-charge situation, but that is the most common. They usually fail due to poor battery connections.
tengals123
thankyou for your reply, i will check it out straight away.<br /><br />cheers!
