NEW wrinkle for '93 Evindrude 115
Party hut Chris
This is going to be a long post because I'm trying to supply information. Fed and Flyingscott have been so helpful already, but just looking for answers here.
Facts (before new problem):
-Oil alarm has been sounding after boat runs for between 5-10 minutes
-I am running pre-mix in the tank, so hopefully no worries of destroying anything.
-Oil line purged and reconnected today (alarm still goes off)
Since I am not worried about the engine getting oil, here is the new problem:
Engine shuts down (sounds like starved for fuel) after running for a bit, but fires back up after I pump the primer bulb again.
It sounds to me like it is only running what fuel is in the system, and then is starving.
Related facts:
-New fuel line and bulb 9 months ago
-New primer solenoid at the same time
Question: Could both of these (oil alarm and fuel issue) be related to the fuel pump? I notice that these lines all feed into the same component.
Question #2: Should I just drill a few holes in the pontoons, sink the thing, and try to collect insurance? (Just kidding!!!)
Some folks would run out and install a new VRO pump.------------I would take the VRO pump apart ( easy to do ) and inspect this simple pump.-----------What does a compression test show on this motor ?-------------There could be crankcase compression issues and that is what drives the VRO pump.
flyingscott
Agree with everything above but I would check the pulse line to the pump and make sure it's in good condition
rothfm
Ensign
When Its dying, squeeze your hose bulb, see if it makes a difference (verifying the fuel delivery possibility).
You didnt specify here if this is the VRO style pump even though you are pre-mixing. If it is, its harness should be disconneted or cut, and the oil side plugged/capped-and you wont get a specific horn for oil.
You have a couple options if squeezing the bulb helps. 1) rebuild the fuel side of the Vro. 2) omit the VRO and install a conventional pump as described here on the forums.
I had a '93 115 also...experiencing the same type issue. Narrowed down to my VRO style pump(oil side plugged and cable cut). Put in a spare-changed the symptom totally, put in another and had a high speed issue...finally put in a 3rd, and its been great ever since. If I have further problems I will be putting in the conventional old school pump.
Party hut Chris
Rothm- YES!! Squeezing the fuel bulb...engine runs beautifully once it begins to bog down.
And yes- VRO pump. Please elaborate!
Also, just to clarify-- FUEL bulb is what I am squeezing to keep her running-
flyingscott
Yes but you still need to verify that you have crankcase pressure and the pulse line is good.
boobie
Agree with the above and if that's okay repair or replace the VRO.
rothfm
Ensign
Was just rereading this.... Whats a good way to check or test the pulses on that pulse line, other than visual/mechanical inspection?
rothfm
Ensign
This post isnt new, but the OP hasnt updated with anything new, and the Pulse line topic came up....
I was real curious about Pulse line tessting, and what is a good way to monitor/test this?
rothfm
Ensign
Should I expect a rapid "bounce" on that gauge, depending on RPM?
