New/ used engine
Zraden
Ok .. like I was saying in other posts, Im not going to dismiss the fact that I might need a new engine.
I have read a ton about people doing swaps and stuff but there seems to be a massive debate
about what internals need to be swapped over. Some info says nothing and its a direct swap over
with the exception of course with the accessories ( starter, alt, distribuitor, ect)
Others say you can only use the block and nothing else. :faint2:
So what is it and why such a debate?
As for the donor, what should I keep my eyes out for, even just for a block. Chev s-10 and Blazer only?
Its a 1990 4.3 with s/n 0C873497
Keep in mind I'm land locked and the engine will never be exposed to salt water.
How hard would it be to switch to fuel injected if that's all I can find for a donor?
Zraden
Re: New/ used engine
The only differences I can see listed from a marine engine shop are:
The freeze plugs are of a corrosion inhibiting material. $10 for 6 plugs .. no biggie
The head gaskets also utilize corrosion resistant construction. $20 difference from auto gasket.
The valve guides utilize corrosion resistant construction. ?
The water pumps are intended for a marine operating environment (seals and bearings). I would be using my old one anyways.
The camshaft is designed to marine duty requirements as needed to move a boat versus a car. Again.. just use mine,
Anything else I'm missing here?
Ayuh,... If ya get a motor outa a Truck, I wouldn't change the cam,....
'n there's nothin' different 'bout the valve guides...
Zraden
OH! I found a 90 chev blazer 4x4 with 160 KM for $500 ready to go.
Just change head gaskets, pump and externals?
