New Trim Rams
saltydogjeff
I think I need new trim rams because it will only fully go down when it has a load applied. But, it goes up all the way fine. It's either the trim rams or something in the down hydraulic lines.
achris
More fish than mountain goat
Re: New Trim Rams
Most likely the seals in the end cap have corroded and swollen up, 'grabbing' the rod. DOWN pressure is only about 1700psi, UP pressure is 3000... That's why it works better with UP than DOWN....
Get a new end cap that should fix the problem.. What size are the end caps? There are 2 sizes, 2.081" and 1.89" (OD)
Chris......
saltydogjeff
Re: New Trim Rams
I'll measure it tomorrow. Is it measured diametrically on the outside on the rod end?
Edit: Saw the "(OD)" - Thanks
