I have an old two log pontoon that seldom sees more than 25 MPH and the fish/depth finder works well almost all the time. The transducer is mounted on the aft face of the starboard log about one inch above the bottom of the log. ... My thought is that any object moving through the water fast enough will create a disurbance around it. If you are going fast enough to create a bubble of air behind the log, I suspect you would also see a bubble of air around your bracket. But, if your boat has strakes and goes fast enough to actually lift the logs and transducer out of the water, that is another matter.
BTW, we recently discussed transducer location with another member and revisited the fact that they only see straight down. So if you are traveling forward at any speed much above idle, you can't react quickly enough to avoid any obstacle you might see on the scope. Similarly, if you are traveling quickly enough to disrupt the flow of water around the transducer, you'll not likely be able to react quickly enough to stop for any fish you might spot.
