Greetings,
I just purchased a nice 86 Bayliner Capri with the Volvo Penta 275 HP (I assume the 275 indicates the HP?) IB/OB on it. It also reads "2.3 Liter SOCH". I would like a source for info on how it works; I need to fix the overheating problem. Apparantly there are 2 cooling systems on this motor, one that draws lake water in (that pump was recently replaced), and a second water pump pump for the closed system with the radiator (I assume that's the one I'll need to replace). I'd like to know how the coolant systems work with each other, and if the water pump is the caus eof the overheating.
Also the starter/solenoid appear to be intermittent, so I need to know what I'm looking at there as well. Does it have an all in one starter/solenoid assembly, or are the starter and solenoid separate, like on my Johnson Outboards?
Finally, what's a good source for purchasing affordable parts for the Volvo Penta IB/OB motors?
Thank you in advance for any assistance.
Cheers
Nate
Cheers
Nate
