New to Volvo 501b
JoeyBottles
I just bought a used 21 ft Grady White with a 1992 501. The p.o. said that the raw water pump was bad, however when we took itbto a shop to buy, they said the pump was good, however the cover was worn.
They also suggested that we flip the cover upside down and replace the impeller which I did. However the outdtive does not appear to be suckingu nough water and it is overheating. I also replaced the thermostat, and suggestions? This is my first boat, im handy with cars though. Thanks everyone!
Re: New to Volvo 501b
Ayuh,... Welcome Aboard,... Ya gotta insure the pump is gettin' good flow from the drive, or seacock, whichever it's usin',...
No vacuum leaks,...
'n,.... If it's a Saltwater boat, the gasket area where the manifolds, 'n risers meet is known to rust, 'n plug,...
JoeyBottles
Thank-You. I will check that out this weekend . Would the seacock be in the leg?
dypcdiver
No, but it draws water from the leg where there is an alloy connection that frequently rots and allows air into the suction side of the raw water pump, check that. If you do a search on here you will find lots about it and also pictures.
Oh and please indicate what kind of drive and motor you have as it make life easier for us to help.
