HawkDriver
- Feb 22, 2005
- 20
Re: New to this need help
Alright, the sun is out and I'm off to the lake.<br /><br />Compression test was good. <br />P S<br />90 95<br />90 95<br />90 90<br /><br />As for the VRO, I'm not even sure there is one installed. I have checked for the box with the black fuel outlet fitting with no wiring as described in the FAQ section. But I'm still not sure exactly where it is supposed to be. At this point, other than the thing with the red valve switch thingy, I "think" I know what all the big parts are on the engine now and I don't see the VRO. <br /><br />There is a fitting that is on the housing of the engine cover area that has 2 nipples, one is for the fuel to come inside the engine area from the bulb and the other one has nothing hooked up to it. Is that where the oil is supposed to come from a remote oil tank for the VRO? There is only the fuel line coming from the fuel tank and no where else in the transom area. There is a hole in the transom area that looks like it may have been where this hose was routed at one time. The guy I bought it from didn't mention anything about the VRO and just said that I should always run a 50:1 mix and I'd be good.<br /><br />I think I have located the recirculation valves. Are they the little elbows that are under each bowl with hoses that are routed back to the fuel pumps? It does have aluminum bowls. I tried to pry the elbows off to check em out and they seem to be on there pretty good. If that's them I'll try to get em off and do the syringe method.<br /><br />Thanks guys.
