HawkDriver
- Feb 22, 2005
- 20
Hi there, this is my first post on this forum so I'd like to thank everyone for all of the useful information that is provided on this website. I have been poking around and searching the posts for the past couple weeks as I have been pondering my problem. Here goes:<br /><br />The history: I just bought my first boat (1986 Glastron) which came with a 1985 or 86 XP VRO 150 HP Evinrude, Model# E150STLCOS, SER# JO577858. I bought it from a guy who runs a pretty nice home business/boat shop and has been at it for about 20 years. I went and looked at the boat and he said he needed a few days to "get it right", well after a week of phone calls back and forth he said that he has gone through everything that he possibly can think of and he just can't get it to run perfect, so I went down and test drove it and decided that for the price I could live with the little problems it had.<br /><br />The problem: At idle it sputters and seems to idle low and dies occasionally. It hesitates when you get on it right away sometimes, but then smooths out quickly after you get her going. It occasionaly seems to cut out for a second when at or near WOT, but it's almost so fast that you don't notice it then keeps runnin smooth. Runs smooth all across the lake at any throttle setting between just above idle and just below WOT.<br /><br />The guy I bought it from said that he had checked everything in the fuel system and that it was all good. He had removed and cleaned the original carbs, and during the troubleshooting had replaced the carbs with a different set of cleaned carbs and he is convinced that it's not in the carbs. Carbs look nice and clean to me. He said the ignition checked out good too, and he replaced the plugs and all. <br /><br />He thinks that it could possibly be a seal on the crankshaft that could be damaged or missing from a previous rebuild. Does this sound like a crank seal? Seems like that would be a continuous problem all the time unlike this situation. I'm thinking fuel supply/pressure or ignition missing sometimes. I should probably take it in to the pros, just wanted some opinions of what I should check here at home because I work on cars and this is my first boat and I have alot to learn. Thanks again.
