stealthy hunter
- Jul 16, 2012
- 4
Just bought a 2003 6 hp 2 stroke ser#0t654xxx. Don't know the history of this motor but the price was right ($100). It starts easy and runs ok, I think it may need idle speed adjusted ......I have the seloc manual. I had planned the following: new plugs, clean and check carb,adjust idle, adjust timing, replace gear case lube, check seals .
Did I miss anything?
Here are my questions ; after reading some people say not to mess with the timing ,should I do it? If so where can I obtain a yacht that will work on this motor?
Any other preventative maintenance I should preform?
Any input will be greatly appreciated
Thanks in advance, Scott
