"New to me motor" Quick refresh in Scotland
spybot
Guys was in Hospital for a bit will update soon, Dr said do nothing strenuous for a week or two. Yeah right Im Scottish will be back at it asap
Stay Tuned :D
spybot
Here are a few pics of the rusted powerhead bolts.
These are well and truly stuck. Whilst in hospital i had a flash of inspiration.:joyous:
spybot
I flipped the motor up side down on the engine hoist.
Even with this better access i still couldnt get the bolts to move.
So on to plan B
spybot
Time to get out the welder :D
I placed a nut and on to each rounded bolt head and now i could get a decent socket on them and out they come.
spybot
The 2 at the rear under the stats were nuts. i managed to get one off but the other was stuck.
I had to drill through it to break the nut.
spybot
[No message]
spybot
Once the power head was off it was time to investigate the low compression on pot 4
It looks like this piston has be roasted alive.
Any other ideas as to what would make a piston deteriorate like this one ???
spybot
Here is the cylinder
spybot
Here is the exhaust chest Why is half it black and the other half clean ????
interalian
Have you torn the carbies down? That's a 140 - does it have 1-3/8" cast in the carbie fronts?
spybot
No the carbs are 1-5/16th on this motor. Still trying to find out what happened to the piston Any ideas ????
interalian
Ah. My '78 doner gave me 1-3/8" ones. Wonder why the change.
<end thread diversion>
jimmbo
The 1978 and 79 140 hp had the 1 3/8 carbs(and possibly the 1977, however since the 77 had the oddball exhaust tuner, it may have had the 1 5/16 carb). 1980 and newer 140 hp and all 115 hp 1973 and newer(prop and crank rated) had the 1 5/16 carbs.
spybot
The Deflectors look OK as the rest of the block is as well.
I think it has been a replacement block not to long ago.
Will check out the carbs to night.
I dont want to end up with the same problem
