Hi Folks, new to the forum and pretty new to boat ownership. I bought a 1991 Alumacraft Trophy 170 boat I'll be slowly rehabbing over the fall/winter. The boat has a Johnson v4 90hp motor on it, but it has no ID tags anywhere to be found. The boat ran great for an entire week for me up in Canada, but the last day it wouldn't turn over. I threw a new cranking battery in, replaced a ripped spark plug wire (going to do the rest) and I'm going to replace the NGK plugs in it with the factory spec Champions. I did some trolling with it and I think I ended up fouling the plugs by the end of the week.
I did a compression test when I got home and I'm at 110-120 psi across all cylinders, which I believe is good (someone correct me if I'm wrong).
Regardless, I'm hoping for some ID help so I can get some parts. I'm wanting to rebuild the carbs, replace the fuel filter, fuel line and bulb, water pump and lower seals, maybe the thermostats too. I think doing all of these things will put me in pretty good shape. VRO is disconnected too.
What do you guys think? Good list? Anything else I should consider doing while I'm at al?
Attached are some pics of the motor. Let me know if any of you guys can help me ID the vintage and model.
