New to Iboats need help please...
devilboy
Hello, This is my first post on this site and would like to say thanks for letting me be here. I have a 1967 Johnson 9.5 and it has about 40 hours on it....yes only 40 hours. I bought this at an estate sale for $200.00 and did a fluid change and put fuel to it and it ran great for about a month. I first had an intermittent cough and adjusted the lean/rich knob and cured that. Then it began to act up when running at WOT. I bought a carb rebuild kit and installed that, put new plugs in it and checked the points gap. Took it back out on the water and now it starts right up, idles great, accelerates awesome but 15 to 20 seconds later it dies at WOT. So I replaced the fuel pump...still not fixed. Seems like the fuel bowl is running dry but will start right back up with out pumping the bulb. So I replaced all the fuel lines on the motor and from the tank to the motor including the bulb, in case of an air leak. Still will not run at WOT. Other than that it is fine. Please I have tried all that I listed and exhausted looking at the posts here for advise and cant seem to fix it. Thanks.....
devilboy
Re: New to Iboats need help please...
I guess that's the only thing left to check. I hope that works. Its frustrating seeing it run so well and then just develop an issue like this. If anyone has another idea please feel free to chime in. I will get a new tank tomorrow.....
1946Zephyr
Yea, it sounds like you have a fuel restriction somewhere. You can check and make sure your lines are all clear and fuel is flowing easily. That is my other suggestion, until you get ahold of a tank. If your bulb flattens out, the restriction is in the tank. otherwise, the restriction is somewhere between the fuel line connection at the motor and the fuel pump. Since you have a new fuel pump on, it should run good.
