Hello
I am new to boating. I recently acquired a fiberglass tri hull deck boat, with a 90 HP Mariner outboard motor. I have several questions about the boat and motor.
1.) The previous owner had started to "restore" it and has removed the steering/throttle cable, how do I figure out how to install the new one?
2.) Do I have to reconnect the above mentioned cable in order to start the engine? I want to see if the engine actually runs before I start anything else. The previous owner claims the boat had been winterized two summers ago.......
3.) The transom seems to be have some minor damage and looks like it has been repaired in the past. Is there a way to assess the condition and strength of the transom without being too invasive?
4.) And here is the stupid question of the year, there is a small hole, it has a plastic "bushing" inside it, on the back of the boat. It seems to be a drain hole, but also looks like it is below the water line. Does that get plugged with some type of drain plug?
I am excited about getting this thing in the water, but don't want to have any problems........I've heard(not sure if its true) that if the transom is weak, the motor's torque could rip the back half of the boat off????
Picture of small hole
Picture of damage, trim pulling away
Picture of crack in fiberglass/motor mount
Any input would be greatly appreciated.
Tripp
Tripp
