WholesaleCabinets.US
Thread starter- Joined
- Jul 9, 2014
- 1
I just purchased a used 18' SeaArk 1860MVT that weighs about 700lbs. It's an aluminum tunnel hull that has a 88 Evinrude on it. The current prop is 14x17. The boat jumps up out of the hole great but top end is 32mph at 5200RPM's. That makes my cruising speed about 20mph. I would like to up my cruising speed to about 25-30 and still have enough throttle to be able to get out of the way if I need to. I'm hoping that I can up the speed, which will also increase my fuel economy because I will be going faster with less RPM's (my thinking at least...)
I am a bit confused on props however and would like some suggestions. The boat came with a 48 SPL and the top speed was almost identical but out of the hole was terrible if there was someone else in the boat with me sitting in the back. I'm a bit disappointed with the current motor (prop) thus far, since it is no faster but drinks a lot more fuel.
What kind of speeds can I expect by changing the prop? I was looking at turning point propellers prop wizard and it suggest aluminum 3 blade 13.25 x 19 and 13 x 19 4 blade. Does this sound about right? I would think with a current 17 pitch prop and such a light boat, a 21 pitch would give me more overall performance.
Any and all suggestions are greatly appreciated.
