workerbee606
Thread starter- Joined
- Jun 24, 2012
- 60
Ok, I was out on the lake last weekend and had the boat beached so we could eat lunch and relax, well a few ski boats came by and the wakes pushed me into the shore so I nudged the boat so the aft was back in deeper water and started the engine and backed up and then pulled her back onto the beach. Well a while later I am swimming around while at anchor and I slide my hand around the prop just to check it out and the back edge of all three blades is fough as crap now, like someone took a file to the back edges. The baleds look true but the back edge is rough as can be , no dings just rough. This boat and motor are only three months old, should I get a new prop and keep the original as a spare and clean up the rough edges with a file or what? The boat runs about the same realy, only difference I noticed was a slight hint of the rpm's jumping above wht she ran before, basicly the motor will run the same rpm for same speed but will fluctuate just a bit now, not much just 100 rpm's or so but you do notice it when running wide open on calm water if you listen and watch the tac.
