New Prop Needed for 2006 Q4 Tahoe ...... Please help
sw6416
Banned
As the title says I am looking for a new prop for my 2006 Tahoe Q4. I think I have gathered all the relevant info needed for someone who is in the know about prop sugestions.
1. The prop I have on the boat now seems to work well if I only have myself and one other person aboard while on a lake outing except for when I make any sharp hard turns with alot of throttle I get prop blowout. With that said most of the time I have more than just two people aboard someone is always wanting to help me enjoy my boat haha. The most common problem I have that I would like to correct is a better hole shot with 4-5 people aboard and better performance while pulling a tube with the same amount of people 4-5 total with any number of combinations on the tube or onboard, 2 on the tube and 3 in boat or 3 on tube and 2 in the boat ect. While tubing the boat just seems to lag to much while turning and too long to get up to speed in the range of 20-25mph. Tubing is the only watersports we do, no skis or wakeboards so need for a mega hole shot to get someone out of the water but a improved hole shot would be ideal with better mid range speed performance for turning ect.
2. The current prop is the factory mercury 14.25 X 21 aluminum prop that came on the boat.
3. Wide open throttle with two people aboard and a almost full fuel load is 4750 - 4800 RPM and 43 MPH ( as I understand it you lose something to gain something when changing props. Top end isnt that important to me as my sweet spot crusing is around 4000 RPM at arond 32 MPH )
4. 3.0 mercruiser, 140HP, Alpha 1 outdrive 2.0 ratio
5. Boat is a 2006 Tahoe Q4 sport, MFG specs say the boat weighs 2062lbs ( I assume thats empty with no one onboard or fuel? ) and is 19' long
I understand there is only so much you can do with a 3.0 and 140 HP but would love to dial it in a little better to suit our needs. I have read numerous threads and heard the 4 blade props are ideal for handling the problems I would like to correct, but also hear that I might be a little short on HP for a 4 blade. I also would like to stay with a aluminum prop if possible to save on cash the wife is already upset I am looking to buy another as she doesnt drive the boat or understand what it can possibly change. FYI not sure if it matters when selecting a prop but I have installed a set of the SX nauticus self adjusting trim tabs on the boat to correct some handling issues as well (FYI best money I have spent on the boat thus far)
*** THANKS in advance for all the help and I look forward to your replys ***
tpenfield
Re: New Prop Needed for 2006 Q4 Tahoe ...... Please help
You might be slightly under powered for people load with the 3.0 engine. Based on the WOT specs, the current prop is correct.
I would try a 4 blade 14.25d (+/-) X 19p if I were me.
sw6416
Banned
Pardon my ignorance but when you say a 14.25 diameter (+/-) X 19 ptch, what do you mean by + / - ....... thanks
Also anyone else with the 3.0 experiencing these issues with my similar setup?
steelespike
+/- simply means diameter should simply follow the application.If intended for your motor/outdrive the diameter will be correct
though different from your present diameter.Often as pitch goes up diameter will go down.
Your numbers are very good 40 mph being pretty typical in a 3.0 18-20 ft boat.
Not unusual for the 3.0 to struggle a little with the 21' for a load and water sports.
The 4 blade will usually improve hole shot,stay on plane better at reduced throttle,seem smoother
and handle better at speed and at the dock.A 4 bld.19" should maintain your rpm but top speed will be reduced.
sw6416
Banned
So just to clarify my mind, you suggest as we'll a 14.25 x 19p. 4 blade?
Thanks again for your help!
steelespike
Yes, but don't get hung up on the diameter. If the prop is for your motor/drive the diameter will be correct.
sw6416
Banned
Once again thanks for the help ...... Today I got my 4 blade Solas 14.25 X 19 prop in and went to install and realized that it hits the fin anode behind the prop. My question is this, I read online you can possibly trim it and also they make a offset one for this issue. Since I have a non power steering system the fin is required for prop torque from what I understand and a flat anode wouldn't apply. However I had to trim about a 3/4" triangle out of the anode to feel comfortable with clearance. So do I need a offset anode or will I be ok with the modified one with the prop torque issue. Thanks
Howard Sterndrive
grinding a notch like that is usually fine. The offset anode isn't much $, but you probably wouldn't notice any improvement over just grinding the original as you did.... as long as there's still the fin there after grinding,
the offset one just looks a bit more "tidy".
jestor68
If notching the anode yourself, make sure it has clearance with the prop pulled to the rear; as it would be operating in reverse.
sw6416
Banned
Quick update ....... Found a slightly used mint Solas 14 1/4 x 19 4 blade on eBay for $80 shipped and ordered new thrust washer and spacer off iboats and now into a new to me prop for around $100. Carried the boat out today and let me say WOW what a difference didn't have a full load as usual but I can already tell it will be perfect for what I need. Jumps straight up on plain and digs in tight turns like it on a rail! Only lost around 1-2 mph which was expected and call me crazy and not sure if its even possible but the boat seemed to run smoother, not like the motor ran smoother but the way it ran out felt smoother. Between the smart tabs and different prop its a completely different boat, when I first bought the boat I was like what the hell after a few trips with the ride, performance and handling around the dock and at low speed, now I am completely happy! Thanks again for all the help!
