New project jumping to the front of the line: 1957 (?) Duracraft
jbcurt00
Well, the dreaded MBS has struck again, and despite other projects in my boathouse, this one has jumped to the front of the line. I truly love this boat. A few things condition wise concerned me, but we'll get to that, and I'm over those concerns anyway.....
Towing it home:
Bow handle:
Duracraft plate:
Details:
The motivator:
Overhead shot:
The bow seems really deep, and when sitting at the helm (NO MOTORBOAT noises were uttered) the boat feels much larger then it's 14' 9"+/- size.
There is some speculation that it's not a 1957, as serial #'s were consecutive across all lines of production, regardless of model. When boat model A rolled off the line it got the next # in the series. When boat B was finished next, it got the next available #. I think it's a 1957 Duracraft Duraflite Custom, so that's what I registered it as.
Since it had a 1958 fat 50 Johnson OB hanging off the back, I registered it as a 1957. M Casey Stock is doing tons of research into Duracrafts & may have more details about serial #'s & year of manufacturer, if anyone wants them. His thread:
1952 Duracraft Sportsman
jbcurt00
Re: New project jumping to the front of the line: 1957 (?) Duracraft
Further 'proof' that it's a 1957 Duracraft Duraflite Custom^^^
Another profile shot:
Ignition plate:
Steering wheel:
The helm:
Another shot:
jbcurt00
Rear of the front bench:
Rear bench seat:
View aft:
Transom knee brace:
Bolts were all corroded & frozen, and the transom was trash:
jbcurt00
There were lots of roots growing under some of the ribs on the interior, and into the area beneath the bench seats, so I rustled up some tools & set about removing the rear bench seat top:
Exterior hull rivet:
Seat top rivet:
Lifting the seat top:
'Flotation' foam, clearly less then sufficient:
'Pan' to keep the flotation foam off the bottom of the hull:
The ugliness below that ^^^ pan:
A nearly 1.5" mat of roots:
jbcurt00
The 'debris' from inside just the rear bench:
The transom:
Surface corrosion only behind the transom ply:
The transom was only 1.25", and because of the downward turned lip, the new transom will be 1.25" thick as well: 1 piece of 1/2" MDO & 1 piece of 3/4 ACX ply:
From another forum, I hear rumor that quite a few Duracrafts were retro fitted w/ bow tanks to reduce porpoising & help w/ the boat listing to the stern w/ an as rated 50hp OB. Bow tank was suspended from the bow cover:
A bow tank will be going back in, but NOT this ^^^ tank. It's got bad scaling inside, and is in much worse condition then it appears.....
Fat 50 remote control:
jbcurt00
Snagged some vintage trim tabs to help w/ porpoising too:
Setup shop and got to work building a motor stand:
Stockpile of flotation foam:
New boat cover & support piping to cover her up once winter is upon us (soon I fear):
Setup a material warming station, building isn't heated if I'm not working there:
Going to be below 30* tonight.... bummer.
jbcurt00
Thought I had some pix of the boat w/ the steering wheel, windshield & all the nav lights removed, but I don't, so I guess their still on the boat :facepalm:
Finally, today, I also started some actual boat work. I love MDO:
Laying out a 19" X 60" area on the back of the MDO to minimize the # of empty knot holes:
Thanks to our northern neighbors for sending me some nice wood to work w/:
Laid out the centerline of the transom, and spaced down 4" to allow for the 'bat wing' stick ups on the transom to all be fab'd from a continuous piece of plywood:
Added a helping hand to give me a way to clamp it to the stern of the boat so I could mark out the profile:
jbcurt00
Then clamped it to the back of the boat:
And traced the top half of the transom.
Then quickly removed it, moved my helping hand down 1/4" to allow me to trace the lower half of the hull's layout:
Moving the helping hand down, raised the bottom of the transom 1/4" and should be a fairly good fit 1st time out. But I have yet to figure out a way to avoid removing the knee brace from the bottom of the hull & get the transom installed. We'll come back to this.....
Notice that the hull isn't symmetrical:
Port:
Starboard:
Oh well, at 56 I probably won't be either.....
Then moved all the traced lines inward a 1/4" to allow for the welded seam:
Then laid out & pre-drilled some holes for screwing the 2 pieces of plywood together:
I plan to use Gorilla glue to laminate the 3/4" ply to the raw wood side of the 1/2" MDO prior to cutting it to shape. Once cured, I'll remove the screws & cut the profile.
jbcurt00
I had to order the 3/4" ACX, it will be on-hand Mon am, and I hope to have it roughed Mon pm. Then layup & glue the 2 pieces together Tues am. It will then have 2.5days to fully cure undisturbed as I probably can't get back to it til Thurs. pm.
I will take some inventory this week, as I have quite a bit of collected boat stuff to move this project along.
I'd really like to have the hull flipped before the snow flies, then I can do some motor work w/ my new OB stand.
Thanks for stopping by!
Very pleased to be working on an actual boat and NOT just be an armchair BYBB......
To the glassers in the bunch, I have not pulled the plug on the FireFlite, but it has fallen another peg in the work flow............
To the Starmada, I have hoarded quite a bit of tin and will be working on some vintage SC tin soon. They are all tucked away & covered for the winter, once again.... My apologies.
GA_Boater
First JB - No apologies needed, for cryin' out loud.
Second - She looks pretty good really. As expected a lot of mulchy wood with roots and is that moss? I swear the gas tank is out of a pick-up. She has some nice hardware on the bow, very original and cool. The long bow is very sporty looking. What's written on the wheel above the Duracraft hub cover?
jbcurt00
Turns out I had a list of boat stuff:
Rivits: closed/blind in various lengths & various solid rivets on hand
Air rivet hammer & 2 heavy duty hand riveters on hand
May bite the bullet & order the HF air riveter too.. :rolleyes:
A few various types of aluminum angle & channel on hand
All new wiring harness for the boat (switches/lights/etc not the OB) on-site
Various gauge tinned marine wire on hand (no battery or OB wiring though)
MDO & exterior plywood for transom & seat cushion bases on hand
GluvIt, Coat-it & epoxy on hand
1.5" rigid foam on hand
SharkHide & variable speed sander/buffer/polisher w/ 4compounds & bonnets on hand
New steering wheel on-site
Original Johnson OB dash panel in good shape so it'll stay on the dash. No other holes to be cut :)
Some maintenance & rehab parts on hand for an OB rebuild (I have 2 or 3 OB's that are possible for the transom)
Remote starter relay solenoid ordered (backorder 10-14 more business days)
Bilge pump, dash switch panel, hose & fittings on hand
New fuse panel on hand
2 new plastic Moeller bow tanks on hand to choose from (I'll hack a thru hull vent fitting off a donor boat soon, have it on site too)
boat cover on site and gray PVC support piping to help keep cover from allowing water to puddle.
Material & large casters on hand to remove hull from trailer & flip it for hull work while on a cradle on site
I have chosen to hoard materials & supplies so that I can't loose steam waiting for parts. The boat building fund kept getting raided for other necessaries around the house & vehicles. So I've been shopping $20-50 here & there since I brought the Duracraft home. W/ the occasional $100 order to secure larger tix items. Helped to wait & watch for a 'deal' on some of the stuff, which helped out immensely.
Best deals to date are the new Moeller 19 gal trapazoid shaped bow tank for less then $95 delivered, which was for a different boat but may go in the Duracraft. Oddly enough a 2nd tank presented itself for $80 delivered that is also new and an 18gal that might even fit better in the bow..... And the Rule bilge pumps: their 12v model 41 3way (auto/off/manual) lighted switch panel for $10 & a 500GPH new Rule auto bilge pump for $37. Turns out the 500GPH was backordered subbed the 750GPH auto on at no extra cost. 1100gph Rulemate Automatic bilge pumps retail $66 from this vendor and w/ the trade up to a larger in stock pump, I'm VERY happy w/ their cust serv...
Working thru how I'll fab a splashwell or how to hide the battery & remote starter relay box. But that'll be 1 of the 1st 'Hey guys, what do you think....?'
Won't be a speed build, but should have some continued progress this week & set some goals set soon :D
Thanks for caring enough to harass :faint2:
jbcurt00
I only meant sorry, but the Duracraft jumped a few other projects & I actually started the work part not 'just' the demo :facepalm:
I need to figure out a 'good' medium term support for the front bench seat backs so I can remove the front bench seat top & get the roots & etc out of it too. I'll probably drill out the rivets & remove the seat top, and temp something together w/ some spring clamps. Then put the top back on & reinstall a couple rivets to hold it back in place. The gunwale at the seat back is already slightly bent on both sides of the boat & in both the forward & rear seat, as well as the opening around the missing splashwell area...
The bow area is HUGE, w/ that big 19gal trapezoid tank, there is still PLENTY of room for some storage & my legs/feet. One of the things that makes it feel like a bigger boat.
It's a Kaiser wheel, w/ a Duracraft center cap. Unfortunately, it is toast. Almost 50% of it cracked & exposed the steel core, which rusted, expanded & has been pushing the bake-lite (or whatever) off. :mad: Too bad, they are highly sought after....
Vintin
Very nice!
jigngrub
Hey JBC! What're you doing hiding way out here in the weeds???:confused: This is prime/cherry/boat porn mang, and should be up there in the main resto forum!!!
You've got some really fine vintage stuff to work with here... for instance:
Them there pictures right there made my sticker peck out!!!:happy:
Did that Canadian plywood smell like beer???
Check all the nooks and crannies in that boat for contraband, looks like someone was using that boat for an illegal grow-op for them magic marlboros by the looks of those roots.
*expletive deleted* I can't wait to see what she looks like when you get'er done, I'm sure anyone that gazes upon her will have multiple eyegasms!!!
jbcurt00
Yep, not as much traffic over here in the Duracraft forum, but for now, here is good.
No barley or hops aroma from the wood, but I do like working with it. Wish I had a miter & table saw, but for now, the worm drive chewed thru it right nice.
I need to take some pix of the bow cover, the PO went after it w/ a grinder. That's what caused the damage to the bow handle. Hit a good windshield w/ the grinder too :mad:
Really chewed up the cap rivets around the entire bow, so I have some work to do there. We'll come back to that too...
Thanks VTF & Jig
jbcurt00
I'll take a pix of the bit in action, but I LOVE the 135* split point drill bit for drilling the head off a rivet:
I don't HAVE to punch a divot to start a drill bit or do a pilot hole w/ a smaller bit.... Depending on the access to a specific rivet, I may pre-drill w/ a smaller 135* split point bit, but I find that it isn't required.
Just bump the trigger a few times on a variable speed cordless drill, w/ a 1/2" bit, and quickly the head is no more....
Okay, that's all I got for today :D
kfa4303
Banned
cool project! can you get the 135* bits at a regular hardware store?
jbcurt00
I'm pretty sure, I don't even remember the brand, let alone where I got them, but I do a bunch of shopping online.
I used to travel quite a bit for work & often surfed the net when I couldn't unwind......
I know I have a great set of pilot point Dewalt bits:
and great set of Bosch DareDevil spade bits:
that are both GREAT for wood, so maybe 1 of those brands??? IDK, those bits are at the shop......
I googled:
135 degree split point drill bit
And it looks like Dewalt labels them split point, and sell a decent size set, reasonably IMHO, so it's likely those are them.....
NOTE: the No-Slip Starting advert on the labeling
I also stay away from HSS black oxide bits. Moved to coated a while ago & couldn't be happier w/ any of the drill bits I use...
jbcurt00
So yesterday I setup & cut out the 3/4" ACX plywood for the other 'half' of the transom layup and clamped it up to keep it flat until I could do the glue up:
I cut the 3/4" larger so there was a 1/2" 'ledge' all the way around the edge of the 1/2" MDO plywood. This gave me a good place to spread the Gorilla glue to (kept it from running off the edge) and a good visual that I was getting good squeeze out:
So today, I stole a half hour just before lunch to run over & glue up the transom:
The $5 spreader from HD worked great, just squeezed out a HUGE puddle of Gorilla & spread it around, right up to my 1/2" allowance at the edge.
Getting 100% coverage w/ the Gorilla, I thought I should probably add a few 1/2" 'vent' holes to keep help make sure I was getting all the air out from between the sheets. Based on the mushrooms that grew while I was teaching this afternoon, mission accomplished:
Yep, good squeeze out:
So I unclamped & unscrewed it:
All in all a good day
jbcurt00
Housekeeping, yep, it's fairly stripped down:
And I briefly mentioned the hack job on the bow cover by the PO:
So I'll likely be removing a rivet or 2 at a time & repairing (sanding/JB Weld, both?) and reinstalling new rivets. I'll shoot some pix of the riveters, buck bar & rivets I've stockpiled. Some of various length in both closed end blind pop rivets & solid rivets. This work is probably a ways off..... to be continued.....
I've also been able to grab a donor or 2 along the way:
Free w/ a Golden Javelin 35hp Johnson:
A fiberglass encased wood boat that is TOAST.... Trailer may be of some value, that's still TBD...
So I also owe you a pix of the OB.
More in next post
