Re: New Problem~PISTONS? Which ones - part #'s having a hard time locating right ones
Just wanted to add an update for anyone searching the forums looking for answers as I was doing before posting. I found several post that were on the right track for me but no one ever posted a fix so I figured I would be nice.
Yes the Wiseco 3151PS Pistons were the correct ones for my 1990 Version B Force 120 engine. Cheapest Place to purchase them at the time I bought mine was
http://www.boatpartstore.com/forcesearch.asp?cat=itemname&cval=3&hval=38&val=119# s piston, rings, pin, and circlips for 1 cylinder was $84.79
Helpful hint pay someone with a hydraulic press to press your pistons off for you I recieved my pistons some time ago and it took about three weeks to finally get the rods out of the old pistons. I tried hammering them out (several times), I made a piston puller, I tried a vise, and I bought a 6 ton bottle jack press from Harbor freight which my husband proceeded to break, then a friend with a repair shop tried his 12 ton bottle jack press with no luck, another friend had a air driven hydraulic jack and had less trouble and got them all four off in a short amount of time.
Once I finally got the rods off and the new pistons on (BTW use a silver permanent marker to mark on the rod which way is up before pressing the old pistons off) I started trying to put it back together. I tried putting the bearings onto the crank first then putting the piston and the cap in I tried for some time but every time I would get the bearings on then put the piston in the bearings would slide on top of one another and after a while I broke one of the cages (they are expensive). Finally I figured it out. I took ATP-201 transmission assembly lube blue and put it onto the rod, put the bearing cage onto the rod and put the bearings into the slots. I gooped it pretty good so it would stay put. I bought a ring compressor from Pep-boys for $8 bucks and compressed the rings, centered the crank and gently pushed the piston into the cylinder so it hooked onto the crank. Then I slid the rod cap in through the reed openings with the bearing cage and bearings gooped onto it as well lined it up and pushed it forward gently with a screwdriver. I used a 1/4 inch ratchet with a long extension and a 1/4 inch 12pt socket and a swivel to put the bolts in. The swivel is essential to getting a good tight fit I did it several times without the swivel and the rod was still loose and I had to take it apart fix the bearings and start over. So save yourself the trouble and use the swivel. I torqued them all to 190 (check twice just to be sure). Once I got them all seated I spun the engine by hand about two dozen times to get them good and seated and check the torque again just to be sure they were all tight.
Hope this helps someone, Good Luck!
