Re: New Poster - Mercury Outboard Year and help
b1551:
Go to this page:
http://www.crowleymarine.com/parts.cfm
Select Mercury as the manufacturer and then select "Search by Serial Range", then select the 40 (1 Cyl) in the drop down model list. Click on 40 (1 Cyl) and it will provide a list of serial numbers and you will see the range 3305152 thru 7045757, the range in which yours fall. Highlight that range and press "Proceed to Diagrams which will take you to the page which I originally sent to you.
There may be individual notes throughout the various component listings which will identify certain parts as being applicable to specific s/n ranges but that one I sent to you is for your engine.
If you are referring to the "Clamp and Swivel Bracket" pages for serial group 1 and two, you would use group 1. Group two lists the other s/n engines that can use the parts on that page.
Let me know if this is as clear as mud.
Gerry
