new pos-neg wire to fuse block
jerkoz
was going to run wire from battery to fuse block under dash. approx.12' (16ft. ss alum.).not sure of wire size to use. horn,lights,2 fish finders and possibly a radio.
Re: new pos-neg wire to fuse block
Ayuh,.... I'd think 14ga. would carry that load, or use 12ga., 'n be Sure it'll carry it,....
Those are all pretty small load appliances,...
tazrig
+1^^^ Your not running anything super heavy from the front so you should be fine with what Bondo recommended.
NYBo
10 gauge is the usual minimum. In your case, that will leave a good amount headroom for any future accessories except high-powered stereo equipment. Be sure to put a fuse or circuit breaker no more than a foot from the battery on the positive feed. A 25 or 30 amp will do it.
