tinbender98
Thread starter- Joined
- Apr 24, 2010
- 3
I have just purchased a 1988 Wellcraft with twin Mercury 150 Black Max's. I have an over heating issue with the left engine and after reading some of these post on the forum I decided to take a look at the poppet, The diaphragm itself and the gaskets were worn but nothing I think that would be detrimental to its process. I did replace with a poppet kit from quick silver and now at idle it will drip about 4-5 drop a minute out of the weep hole and when I take it up a little over 1000rpm it starts to stream and seems to get even stronger with every advance in on the throttle. I took it back apart and didn't recognize any issues from me installing it. Just to check myself though when in installed the poppet it seems to press against the diaphragm opening that little passage between "Circles" and I double checked to make sure that the poppet itself seated into the rubber seat in the block. Any ideas of why it would be leaking like this any advice would be appreciated! Thanks
