New pontoon steers Like a Truck
staudy
I have a 2011 Starcraft 20 ft pontoon with a 50 hp 4 cycle Merc big foot and it steers harder than any pontoon I have ever owned. It has a steering friction adjuster on the motor that I adjusted as loose as it would go and I also lubricated all the steering linkedge and greased the swivel bracket with merc grease. It only helped a little...What do I do? Only 30 hours on the rig.
EGlideRider
Re: New pontoon steers Like a Truck
Back to the dealer. A 50 hp shouldn't steer that hard.
Jeep Man
How is it at the dock and going at minimal throttle?
rickdb1boat
Could also be it has too sharp of a bend in the cable somewhere. Like EGlide said, I'd take it back..
lmuss53
If it is tight in one direction and not the other it could be the trim tab, regardless I am with the other guys, it should not be like this and it is on the dealer to fix it.
5150abf
Welcome to iboats.
Concure, on a new boat you should not have to do anything, get it back to the dealer and have it looked at.
SoArkSi
Back to the dealer! I have a 95 model barge with a 79 model 100 evinrude and it turns with very little effort
