New Pontoon Boat Owner - Many Questions
EricJRW
Re: New Pontoon Boat Owner - Many Questions
I just pulled the tape - haven't run it since. Any idea how to check to see if it's working properly? (I guess I'll find out if I empty the oil reservoir.) Thanks for the info on disabling the VRO - I was wondering if that would be all it took. It seems a bit paranoid to just forget about it, but that seems to be the consensus. It’s almost like switching out my radial tires for steel wagon wheels to eliminate the risk of a blowout, but based on the comments so far I guess I’m coming around to it.
I don’t have a picture of the trailer without the boat on right now, but I found this one that is almost exactly the same (except mine looks like it’s been through a war). Mine just doesn’t have the carpeted bunks on the back. Hopefully this picture will let you see how it works. The winch and cable only change the angle of the V’s on the back axle. The back end moves up and down a lot. The front not so much.
Thanks for you help.
The easiest way to test the alarm is to ground the wire from the over-heat sensor. Disconnect the wire (there should be an in-line lug) and ground the wire. Your alarm should sound. I thought I had a picture of mine, but I don't (no matter how many pictures I take, I never have the right one). The sensor is at the back of the engine, perhaps near the top. It will have a single wire.
That's a very interesting trailer. So to set it on the ground you must also lower the jack? The reason I'm interested in this is at the end of this season I want to set my boat on dry land to so some work. I don't own a trailer, so I need to find something like yours, or at least a "real" scissor trailer.
snakeskinrug
Eric, thanks for the info. I'll try to test that sensor tomorrow.
As far as the trailer goes, I don't think it would be a good option to put the boat on the ground. I've had the trailer hitch on the
ground before and I don't think the entire length of the pontoon would be sitting on the ground even if you cranked the back all the
way down. I could be wrong about that. I've never had the trailer all the way down before. But then, you'd still have to pull the trailer out by hand. That seems like no fun to me. I suppose you could lower the back down and drive away very slowly. The sound of scraping metal would be horrible but it would slide off. You'd never be able to reverse it though. I'd shoot for the type where the entire stage cranks up and down.
Thanks.
newbie4life
I don't have any pictures handy... and the pontoon is at the campground. But, as I look at the picture of your trailer, what about a couple of bouys, laid horizontal and parallel to the trailer's web bracing on each side? They're just gonna 'bump' the pontoon into position as you slowly pull out of the water... Just a thought, depends on how much room you have between the pontoons and the trailer.
snakeskinrug
Interesting, I was thinking along the same lines but carpeted 2x4's at an angle so that it slides into place. What kind of bouys were you invisioning?
newbie4life
Depends on how much room you have - 2 x 4s carpeted may be better in your case. Just something to gently nudge it into place while you pull it out of the water. Otherwise, my thought was just the air filled bouys from Wal-crap. ;)
snakeskinrug
I'm about to take that to the next level, by wrapping my 2 X 4's in neoprene (for cushioning) THEN carpet.
If you don't mind my asking, where to you plan to get your neoprene from?
I have used a crank-up trailer like in the picture. It had side rollers mounted vertically towards the rear so that when the boat was being pulled out of the water it would pretty much be self aligned. There was probably 3-4 inches play difference between the width between the pontoons and the distance between the rollers. Sorry no pics. It worked very nicely.
Enjoy your new boat.
