New piston tapping ngk plug
ggboat
89 Force 85HP. I just put in a new piston in #2 and heard a little more rattle than usual.
It's getting quieter with 2 hrs break in. I can clearly see the piston is tapping a little on the plug; NGK BUHX. There's also a little dent on #1 from plug (old piston, 125 compression). Could i add an extra washer to the spark plug?? I've been using ngk for years.
jerryjerry05
Re: New piston tapping ngk plug
If your plug is hitting you have the wrong plug.NGK or Champion it shouldn't hit.
Is it the perma-gap plug? UL-18V Champion.That's what came with Force as standard equipment.J
ggboat
Thanks, It's permagap. I found some old champions UL-18V . They are about 1.5 millimeter shorter threads than ngk. I'll try that.
