Re: new pics on project
ive been pretty lucky on the tool section. all i have used ia a 4.5" angle grinder, circular saw, jig saw, and corless drill. i had all of those, but i have spent a little over $1000 just at the epoxy/fiberglass store i go to (dang epoxy resin). still $3000 for this boat completely rebuilt is well worth my time!! better than paying $5000 for one just taken care of.<br />for drainage, i set it up like the factory. have a pvc pipe under gas tank that lets all water that goes into ski locker out. the water that goes over the bow, there will be another pvc pipe that goes from beginning of the floor down to the first x-member. i thought long and hard about a drainage for the part outside of stringers, but since i know where everything is if many years down the road it gets wet foam, i have a few ideas to drill drain holes. i know where the water sits from when i tore it apart. i plan on upoulstry once i have it working. starting with the pieces that are on the top outside. they were pretty bad, and getting worse! seats have some small cracks, but will prob be next winter project.
