Re: 1964 15' Starcraft Aluminum Runabout Project
Nice score!
I picked one up last year with a good running 20hp mercury (slow but steady
it came with a new paint job, no windshield, and tiller steer
I kinda threw it together to get on the lake as soon as possible, made my own steering bracket (have a proper one via ebay waiting to go on) and made my own throttle control via a few pieces of metal, drill, bolts, and plastic washers.
My FIL said it it looked like a frying pan handle :redface:
My shifter was a cable end tied to my seat, worked great, push and pull to shift.
This year I make the boat nice
I have done lots of shopping for parts on ebay and I plan on replacing the floor and seats.
I also got a new windshield installed from a trihull parts boat my FIL picked up for the engine.
Right now I have a second matching 20hp I found cheap while looking for a 40-55hp engine.
I managed to get it running and pumping water before the snow fell
My hopes is to run them side by side as duals...
I have the linkages figured out and I think I can make it work well.
My plan for this spring is to replace the current floor (was replaced by the previous owner but it was never sealed)
I want to put in a flat floor as the current one has some curve to it making it hard with the current seat setup, and I want to install pedestal seats to clear up the floor.
I also have a new steering system from the parts boat I plan on playing with, but it will need a new cable and maybe some lube...
Currently the transom is holding and seems solid but noticed it is not as solid as it should be.
I plan on replacing it once I get all of the bugs worked out of the other engine, and decide that it will actually work.
I also have the proper mercury controls for both engines now, and they are setup so I can link them side by side and mount the handles on either side if the dual engine thing works out for me...
I also picked up starter motors for both engines, and everything needed to hook them up not counting the battery.
It should be a fun project once the weather calms down
