New member with a ?
Rubicon_Randy
Hello all,
Just purchased a 1987 Skeeter Strada FS-80 with a Force 50 hp outboard and automatically replaced the water pump housing and impeller. After the repair I hooked up the water ears and started the boat. The only water coming out is at the exhaust port just under engine cover. I was curious on how strong that flow should be off that port or if there is supposed to be a actual weep hole for the water that has pumped through the cooling jackets. Any help would be greatly appreciated.
1983rinker
Re: New member with a ?
It will just spit that all it will do. As long as water comeing out that hole you are good.
