tnduc
Thread starter- Joined
- May 2, 2007
- 292
I just installed a new ignition switch purchased on this site. The switch is the 3 position, push to choke OMC switch for my 91 Evinrude 90hp. First of all, the wiring diagram did not match up with the actual switch I received. So, after several trial and errors the switch does almost everything right. Position 1- off. Position 2- run, push to choke. Position 3- start. However, after starting the engine and letting it run I return the key to position 1, but the motor won't turn off. I have to choke it or remove the emergency kill switch to turn the motor off.
Any ideas? I know (think) it might be a crossed wire, but I don't know which one since everything else works perfectly.
