New impeller, Tstat, poppet valve HOT
tashasdaddy
complete water pump kit, guys i'm stumped. still running hot, and getting not water, ran hose up water tube when lower was off. 71 50hp 50712 i know the new temp sender and old horn works.
Walker
Re: New impeller, Tstat, poppet valve HOT
Probably need to pull the power head and check the watertube and grommet at the top and check the base gasket.
tashasdaddy
dropped lower, impeller vanes are dust, housing has gotten hot enough to start to melt. did not run dry. rotated driveshaft in correct direction after installation and everything was smooth. these were brand new OEM products.
Walker
Is this the same motor that ate the other impellor? If so then something is preventing water from getting to the pump.
tashasdaddy
yep it's the same one. i check that yesterday and again this evening. Tomorrow, i'm going to attach a hose to the water tube and see if i can get water thru the engine.
Barnacle_Bill
I'd be surprised if you don't find a blockage in the block. Not much water can get in the pump if it hasn't any place to go. Curious as to what you find.
Walker
Tasha, are you running it on muffs or in a barrel? I'd try it in a barrel with the water level well above the pump level. That should at least keep it from eating the impellor.
tashasdaddy
muffs, with plenty of water.
tashasdaddy
here's the pics of the second one, notice the melting on top of the housing.
F_R
This is from way out in left field, but the inner exhaust tube wouldn't happen to be missing from that motor would it?
tashasdaddy
everything is there thats suppose to be.
ezeke
Is the mosel number 50172?
The impeller is running dry. What is the grey material clogging the water outlet?
Willyclay
TD, was this a known problem with the motor when you got it? Hang in there, I know you can whip it!
tashasdaddy
exeke, that is melted impeller, connect muffs to lower this morning, and put old housing on and get water running freely, of course with out and impeller, seeing i don't have one right now. when it gets shady where the motor is i will connect a water source to the water pipe.
