muc
"Retired" Association of Marine Technicians...
Thread starter- Joined
- Jul 7, 2004
- 2,450
I see a lot of posts about I/O engine alignment. From doing this job I know it can be a little tricky to tell if the engine has to go up or down, or even side to side. Mercruiser has come out with a new alignment tool part number 8M2001017. It really makes this job much easier. Its MSRP is a little under $70.00. It works on all the same products that the old tool part number 805475A1 works on except the TR/TRS drives. It is an inner bar with an outer sleeve. Every mechanic that has used it say?s ?why didn?t I think of that?
If you?re thinking about buying some aftermarket crap off of e-bay I really think you will be much happier with the real thing from Mercruiser.
Good Luck Muc
Good Luck Muc
