New Honda 2hp Break in procedure
mesajeeper
I just picked up a new 2hp Honda motor and have a couple of questions about the breaking procedure. My dealer told me to not run the engine at any constant spead for more than 5 minutes or so but to use the full range of throttle. My concern is that when reading through the owners manual, I read the following: "Proper break-in procedure allows the
moving parts to wear in smoothly for
best performance and long service
life.
For the first 10 hours, run the
outboard motor at low speed, and
avoid full-throttle operation."
So it sounds like I should avoid full throttle but says nothing about not maintaining constant RPM's for any length of time. What should I do? My instincts tell me to follow the manual. Should I also avoid constant RPM's while also avoiding WOT? We will be hitting the lake tomorrow and I would love to troll with the motor but I want to break it in correctly. Thanks in advance for any advice.
Sea Rider
Re: New Honda 2hp Break in procedure
Assume it's a 4 strokes engine, right ? Just follow owners manual...
Happy Boating
mesajeeper
Happy Boating
Yes, its a 4 stroke. So does this mean that as long as I don't run WOT I am ok? I can set it at 1/4 throttle and troll all day?
Sea Rider
This is the break in period chart for Tohatsu 2.5 HP 4 strokes engine, nearly same for Honda 4 strokes.
1-10min--10min-2hrs----- 2-3hrs---- ---3-10hrs--- After 10hrs
*Idle- *Less than 1/2 *Less than 3/4 *3/4 throttle *Full thottle
*Throttle setting.
Achieved hours can be combined with lower throttle settings as not to maintain constant rpm's for extended periods of time.
Change engine and tail oil after break in period.
Happy Boating
Sea Rider
Sorry double post...
