New grey fuel line
Gizmoray
Can anyone tell me why the newer fuel line/hose collapses at any connection? 2 boats won’t run for more than a couple minutes after hitting throttle. I’ve pulled a couple lines and found at the connections, the inner clear liner was completely collapsed. Using 3/8 inch line. The grey stuff from marine shops. Have 4 different connection on my boat. All are plugged.. inner liner collapsed.
Picture a butthole!!!
Mc Tool
Yep ,probly alcohol in the fuel ........and you should probly pick a different forum signature .😂
airshot
Same old story, buy the best and your done or keep replacing it every year.
The price of two junk gray hoses will cover the cost of a quality A1 fuel line that will last for many years.
rolmops
I have this feeling that these grey fuel lines that you are talking about are from before the year 2000 .the newer outboard fuel lines are impervious to ethanol and will not rot out or collapse , unless you are using very high percentage ethanol fuel.
airshot
Hmmm...did not know that, but...purchased a new gray hose about 5 years ago and it fell apart ( the inside collapsed )two years later and I replaced it with A1 fuel line and it still looks like new..no issues.
jlh3rd
it just does.
grey bad....black good.
