New Force Tilt motor leaking where line is
tyblossom
My husband is trying install a new Tilt trim motor on a 125 HP Force outboard. We bought a new motor, and then a used valve body and when he put it together and on, it worked..but started to leak where one of the lines goes into the valve body. Does anyone have any suggestions on fixing this? Everything seems to be ok with the unit, just this is leaking. He's almost to the point of using JB weld on it, but I'm wondering if he can re tap it and some how get a brake line adapter that will be larger that what he has as we think maybe the threads got stipped or something. What would you do? Where would you get what you suggest? Napa? Thanks in advance to this newbie :)
Stephanie
adamjr
Re: New Force Tilt motor leaking where line is
I am guessinf RRitt will be around to answer soon enough. There are a couple of products you can try prior to tapping but all require EXTREME care.
The simplest one, if the threads are there but worn that I have used with some success is a product from Permatex:
It is available at Ace hardware for around $12.00. It is a 2-part epoxy that you mix and apply and then use a supplied thread release agent on an appropriate sized fitting and thread it in when the putty is setting but not hardened. Leave it for a day and remove it and clean the interior. You have to be careful not to obstruct the seat or the orifice.
Then there's JB weld. Pretty much the same scenario.
There's also a product called Alumiweld. I got some from Harbor Freight. I think it was around $8.00. The Permatex worked for me on my old Rude tilt unit so I never used the Alumiweld. It's a brazing rod you use with a propane or mapp torch. You are supposed to heat the surface as though you were soldering and then touch the rod to the surface. Then while it is still molten you thread in a fitting. I would be afraid of this because you A) have to disassemble the valve body completely so you don't melt any seals inside it. And B) I would be afraid to warp the aluminum and then you have much bigger issues.
As far as drilling and tapping it depends on if you have a line that is long enough that you can cut it and re-flair it (has to be double flaired). You absolutely can not use a compression fitting. What you need is an adapter taht will go from the standard nut for the tube size you have up to the next nut size. The adapter on the line side will have to have the appropriate flare. Then you can thread your old line into the adapter after the adapter goes into your larger drilled and tapped hole.
tyblossom
Thank you so much for taking the time to help us out. We bought the stuff you suggested and it has to cure for a day, so we don't know if it will work...but hopefully it will.
Thanks again so much!!!!
Stephanie
RRitt
try putting a size 009 oring into the hole.
adamjr
Is that in place of using a thread sealant?
Stephanie, how did the Permatex work out for you?
