New floor in 15ft half cab
bonz_d
Re: New floor in 15ft half cab
Neat looking little boat, well built also. Which is why I find it hard to understand why they used such thin material for the decking in the 1st place.
damon99
little bit of an update have finished the floor and the front seating .
have put 1 layer of glass over it
damon99
i am trying to work out my seating , i have tried normal style boat seats
but they take up way to much space (don,t leave any room to move around),
as i have to use pedastals i was thinking of using (i think)stand up seats (like a big bicycle seat).
as they are fairly small .
or is there a seat and pole that can be removed or folded to the side of the boat
any sugestions would be welcome
jbcurt00
Leaning post?
Depending on how you use the boat, you might have 'fishing' seats or leaning post setups that you can have extra bases set on deck & then only use them when you're fishing. Or swap the main seats & pedestals out to the fishing seats while fishing.
Might look at the seats that have a back that can lean forward, so you can sit in them facing the stern. Many center console boats have a bench seat that does...
I tried to find a pix quickly but couldn't. I'll post it if I do.....
damon99
this is the finished boat, looks 100% better than when i first got it .
and now its safe on the water
damon99
the stand up seats are perfect for a small boat like this.
as they give you seats but still give you room to move .
i tried a set of normal padded seats but i couldn,t get past them to get into the cab as they where to wide
and also took up a lot more room .
