Texasmark
- Dec 20, 2005
- 15,019
Was surfing props today, starting with iboats (of course) Merc props.
My 24P XL Ballistic lets my stock 90HP, 2.3:1, 4 1/4" gearbox, 17' tin lizzie, run up around 5600 to 5800 rpm's in a straight away with 2ea. 200# folks, fuel, and gear....normal load. Holds pretty good in a tight turn whereas I cut her down out of WOT prior to hitting the turn, and half way through, I goose it and she just screams, not breaking loose, just like a race horse, loves the excitement, the engine and the soul mate sitting next to me...hanging on to what else but me (the soul mate)...... We're running 48-50 GPS...wake is in my Avatar. We boat on a 1000 acre lake during the week when you have to look hard to find another soul present, so we are not endangering any one....and we do fish between spurts of "Second Childhood Exuberance", the boat has BIA floatation/certification, rated for 130 hp, running 90, and we do wear our life preservers......did I miss anything. Grin!
This prop has a rubber built in hub. Was looking at possibly a Laser II, Quicksilver Lightspeed, or Solas Titan, and saw a lot of the plastic crap for hubs. Also saw at least one that boasted a rubber separate hub rather than plastic. None of them talked about power tip. thin blades, nor blade balance and casting uniformity.
Haven't had anyone "belly up to the bar" on what's obvious: Plastic doesn't yield when you shift and doesn't yield when you hit something.
Seems the industry, in it's infinite wisdom on cost cutting and all that "stuff" has come to realize, through disgruntled user feedback I'm sure, that the the plastic hub/brass molded insert just doesn't get it. I know there will be a dozen or so purists that swear by their plastic prop hubs but I have walked the walk and talked the talk and after 55 years of boating, I'm not buying the argument.
Soooooo, if I want to upgrade to one of the aforementioned props in 25-26 pitch, can they improve upon the Michigan Wheel (now) Ballistic, and if so, which one will get me back into a rubber hub, even if it is a replaceable throw away rubber hub?
Stiff question, looking for a stiff answer!!!! Come on big guns, hit me with your 00 buckshot. Grin.
Mark
Mark
