new f225 no water pump stream indicator?
magnoman
This was the first time since getting my 03 F225 I had it running on ear muffs
for 5 min or so and did not any water coming out of the indicator? seems like enough time for the thermos to open, motor felt warm.
did not want to let run and over heat. I was going to put it in the water next week but now maybe I should pull the lower unit and check the pump.
But my Q was should that be enough time to get the motor up to opt temp?
magnoman
Re: new f225 no water pump stream indicator?
Just took of the lower unit and the checked the water pump impeller it looks perfect. still no pee indicator?
magnoman
I even blew out the water indicator hose still nothing,..... help!!
micel
Have you tried reving engine to 2000 rpm for a split second?
rodbolt
use a bungee cord to firmly secure the muffs to the case or it wont pick up water. sometimes I have to bloip the throttle a bit as well. the curve on the gearcase tends to let the muffs suck air. a bungee cord is a must.
magnoman
Thanks, I hope that is all it is.. I did see water just rushing out the sides of the muffs.
One more thing , Have a good ides for getting the left side thermo out?
what where they thinking when the designed that!
magnoman
sorry Rodbolt, Just had seem your repiy in the last post about the thermo, Thanks so much.
magnoman
Ok used bungee to secure the muffs still no water indicator, not even a drop?
Not sure were to look next
boatguy823
its been my experience that the f225 and f250 don't like muffs. try putting the lower unit in a large drum or tank of water then start it up. If it doesn't pick up then need to check things a little further.
magnoman
I will try that would not even know where to find a big drum , but never in my last three yamaha's have I had this problem with muffs.. I am mean there is not a drop coming out .should I be getting water indicator when motor is cold?
I pulled the lower unit and checked the impeller it looks to be fine..
Not sure where els to look, that would cause this issue..
ricwing
I have the same motor and same problem, put it in the water no problem, just will not p with muffs.
magnoman
Well I am going to get a barrel tomorrow and try it!
I purchased the motor from a very reliable outboard rebuild company and they said the motor was totally gone through and only had 400hrs on it and the only problem they found that the timing belt was off by one notch. It runs and looks in great shape so was wondering how could this problem have gotten overlooked...
magnoman
Ok, I cut up a old garbage can and filled it with water and put the lower unit down in there up to the cavitaion plate and I did get water to come out the indicator pee hole but a very weak steam even when i reved it to 1500rpm?
mikesea
I had posted about the same problem a yr.or so ago.Its just some weird thing with some of the newer yammies.Once I put the boat in the water ,all was fine.I had a friend break an impeller.,So I helped him replace it .pulled the lower down again,checked as you did.Finally i posted here and got the same good advice your getting today.Good luck.
