New EPA approved tank - '76 15hp 15R76A
lemondrop9344
Will these new tanks work with an older fuel pump motor? Engine seems to be starving for fuel after a few minutes of run time. I have fresh fuel, rebuilt carb, new points, plugs & condensors & 95 # compression each cylinder. It's almost like the motor is running way too rich as the amount of fuel consumed seems excessive. Any ideas or suggestions?
Will Bark
Re: New EPA approved tank - '76 15hp 15R76A
With the new tank without vent you must loosen the cap before it will feed fuel; at least that's the way my tank is.
boobie
Try your good old original tank once and see what happens.
