New engine started - chuffing sound...
stant1man
Hi guys,
I installed a new 350 Vortec with 4bbl edelbrock 1409 into my boat and took my time over wiring/plumbing and whatnot.
Got the engine started on the muffs tonight, the first thing i noticed was with the new waterpump both circulating and raw the muffs got sucked onto the outdrive good and proper... this concerned me a little which I will expand on in a minute.
The engine took what seemed like forever to start and at times we had to give the starter motor a break.. eventually she kicked and since then she will start on the button. I was happy it happened this way as it gave the oil pump plenty of time to prime the engine.
Now onto the running... immediately i noticed an unusual chuffing sound... I have no idea what it is but its definately there... like a steam train chuff chuff chuff chuff....
There are new manifolds and risers installed so I suspected perhaps it was something to do with this, can anyone shed any light on what this could be...
Anyway after around 5-10 minutes of idling time the dash alarm(not engine) sounded to say the temp was entering the red, I expect this is due to there being insufficient flow from the muffs so I shut her off with the niggling worry.... what was that chuffing noise.
bruceb58
Re: New engine started - chuffing sound...
Maybe your raw water pump dying because of lack of water. You have the hose on full?
stant1man
I considered that, my old water pump would certainly not suck the muffs on like that i can tell you... i think i'll get her to the water and let her drink all she likes... cant be sure its the pump though :-S
Ayuh,.... Where is the noise originating,..??
Don S
If you are hearing it out of the carb, a tight intake valve that doesn't close will cause it. could even be crossed plug wires.
stant1man
I have located it to the starboard rear of the block.. when i get close it's actually more of a ticking.... do the valve clearances need adjusted on this type of engine?
Also, I need to check the plug gaps as i don't think they are correct. Hooked up timing light and it's flashing intermittantly on cylinder 1 but consistantly on others. Manual says 1.52mm, can anyone confirm?
Best wishes,
Stan
Don S
Not sure what manual you are looking at, but the marine manual I gave you a link to for your engine, calls for 0.89mm
That is also assuming you are using the Prestolite ignition system Volvo had in it.
stant1man
Don S
What distributor do you have?
stant1man
I suspect you may be right on my plug Gap Don, you usually are but the ignition system changed from prestolite to EST so I am not sure.
Got the feeler gauges and timing light at the ready. I presume it is still 10degrees BTDC or should it be 12 now that I have the 4bbl?
Best wishes,
Stan
Don S
You should use the 1.5 gap with the EST ignition. Timing will be the same with either carb.
stant1man
1.5 Gap now done, ignition timing set to 10 degree BTDC engine sounding sweeter but not idling perfect... a little lumpy.
As I was setting the timing the timing light was still missing beats on number 1 and I suspect that the supplied ignition leads and delco plugs (which are now the long threads) should be replaced. I would take advice on which kit to get particularly with regards to the plug. I was getting little shocks off of the port side riser as my bare arm was resting on it so I suspect some sort of HT leakage.
Onto the chuffing noise which is now much more clearly a ticking noise now that the engine is idling quieter it's easier to identify. Are there valve clearances that must be set on this engine? I thought it was all hydraulic or perhaps im misinformed.
Thanks again,
Stan
Don S
If you are getting intermittant spark on #1, it sure isn't going to run right. move the plug wire to a different cylinder and see if the problem follows the wire. Could also be a cracked cap, or bad plug.
stant1man
The cap is 100%, checked and all ok.
Found a crack in the ceramic on plug 7 so I think the plugs are the first port of call.... Don, do you know the comparible NGK part number?
Best wishes,
Stan
Don S
I don't know, Volvo only gives Volvo part numbers and I have no idea what they convert to anymore.. What came with the engine when you bought it?
stant1man
Researching previous posts suggests - NGK BPR6EFS
The plugs that were installed when it arrived were Delco.... I don't have the part number handy.. I can check tomorrow.
stant1man
I couldn't wait lol... I went out and pulled a plug, they are ACDelco MR43LTS
stant1man
Brilliant Don,
I'll order them tomorrow.
Thanks again,
Stan
