1988 4.3l OMC Cobra
Another issue with this lovely boat, I had a guy install a reman. engine a couple months back and haven't had a chance to break it in yet as I've had other issues which now are resolved. Thanks.
The oil pressure is reading around 50 psi at idle and quickly jumps to 70 - 80 with throttle. Can't tell you the exact rpms as that issue comes next.
Main question: is it normal for an engine to have high oil pressure during break-in?
Unless I hear yes, tomorrow I will be checking the sending unit and gauge. If those are good I will be contacting the engine builders to see if they put in the wrong oil pump.
Other than that, what else should I be looking at.
Thanks
Thanks
