reelfishin
Thread starter- Joined
- Mar 19, 2007
- 3,050
I am setting up a trailer for one of my boats and wanted to get a few opinions on which way I should set the bunk boards. I am replacing all the brackets so I have a choice, either to set then end wise or flat.
I feel that endwise is stronger and supports the weight of the boat better, but flat they will spread the weight out a bit and support a larger area on the hull, but they will be more likely to flex and give, and not as strong overall.
Any one have any other opinions or reasons for either choice?
The trailer currently has the boards laying flat and has recessed bolt that are near imposible to keep tight. The bunks also flex a lot and don't support much weight between the uprights. I can pull the mid section of each board away from the hull enought to get my finger inbetween with the boat on the bunks.
Also, should I use 2x4 or 2x6 boards? The longest flat section on the hull is only about 8' long, so I also don't see the sense in making them any longer since they won't contact the hull up front anyhow. The current bunks are 16' long and have those roller conversion strips on them that simply do not work.
Also, am I right in that the lower keel rollers should support the main weight and the outer bunks should only level or support the boat? Thus allowing the boat to roll somewhat freely back and forth? In other words, more weight on the keel than on the bunks?
