G
Guest
Guest
Running the 22 ft Hiliner Center Console (200 Oceanpro) after a major refit with new gauges (BRP)
The Tach seems to be reading correctly at idle and up to about 1/2 throttle, then it only goes up to about 3800 rpm at WOT, in spite of the fact I can hear the engine spinning way past 4500 and close to what she should be at at WOT (5500 -5800).
The prop is a 15 X 17 (older) SST, so I know if it is over propped, not by that much.
I may check the pole setting on the backside of the tach, but has anyone heard of this before?
I want to dial in the right prop, but I can't do that until I know what the motor is actually turning.
