I'm new to boating and now to this site, although I've already searched and learned a lot! So, I picked up my first boat 18' open bow bayliner with a 2 barrel 4.3/ alpha one and a 17p prop. Issues first were misfiring/backfiring at 3/4 throttle. The marine shop the previous owner took it to replaced;fuel filter, plugs, rebuilt carb and it still had issues. I purchased the boat as is and I did a little visual inspection and found cylinder 4 plug wire really corroded. Installed a cap, rotor, wires, new plugs gapped to.035, set idle to 650rpm and timed it to 8? btdc and fully advance hits 26? now it runs like a champ but will over Rev heavily at full throttle. I can hammer it and get from 4500-5500rpm in a second and the engine pops /backfires at higher rpms. I know max rpm is 4300-4800. The engine never backfires/pops/misfires between 650-4800rpm after my tune up. At 4800 I can only get 30 mph on the GPS. Questions; does the thunderbolt IV have a Rev limiter causing this popping/backfire? Any opinions on prop or anything else to get this thing working more efficiently?
