ixxbigdxxi
Thread starter- Joined
- May 23, 2011
- 4
I have a 66 Mark Twain with a Mercruiser 150 - GM 230 I/L 6. This boat was given to me and I have been working on getting the engine is top shape. We've taken it out a few times and I noticed the ammeter didn't move much during the short test trips we made, so I took the alternator in and confirmed that it was no good. I replaced it with an alternator out of a 66 Chevy C10 pickup (same engine and same mounts). Had to buy a pigtail connector as the alternator that was on there appeared to be the original alternator and had the brushes in a "brush package" sitting outside the back of the alternator.
I didn't connect the R connector to anything as there was nothing connected to in on the old alternator but I do have the Blue wire going from F to the voltage regulator. The red/white wire is of course attached to the BATT terminal which I followed up the ammeter than from there a red wire comes from the other side of the ammeter back to the starter then from the starter to the battery. GRD of course to ground. I also followed the white wire from the voltage regulator and it goes to the ignition switch, also seems to have a cable spliced from the white wire that goes to the + side on the coil.
When I had the engine running after replacing the alternator, I grabbed by multimeter and expected to see around 13.5-14.5 volts, but it was only reading 12.2 volts. Am I correct in assuming with the engine running that it should be reading 13.5 to 14.5 volts? I checked all connections and ensured they were secured. Also turned the screw on the voltage regulator to allow more voltage but there was no change in the reading. I did take the alternator back to have them test it and it tested ok. I'm guessing it is probably this regulator and my question is, is there a way to bypass the regulator for a second or two to ensure the alternator is working? Guessing I could jump the white and blue wire? Is there a way to test the voltage regulator? How many volts should I be getting out of the blue cable and white cable when the engine is running? Also, if it is the voltage regulator, the chevy truck that the alternator is from has a different type of voltage regulator - http://www.oreillyauto.com/site/c/detail/MPI0/2VR4.oap?keyword=voltage+regulator&pt=02115&ppt=C0330 . Could I use that regulator instead of purchasing a transistorized voltage regulator like the one I took out? Sorry such a long post but making sure I put make it as detailed as possible.
