Yes 2x4 pushing off rams. If gimbal bearing is rusted to the driveshaft can be hard to remove- this can happen if bellows leak water . Can also get seized to coupler but would not expect that given time involved.Boat is in forward gear, trim rams removed, speedo tube remove, 6 bolts removed. Dang thing won't budge. Any ideas why a newer drive would be stuck? What are my options, just the 2x4 trick?
This is my concern at this point. Just wanted to make sure I didn't miss anything. Thanks!If gimbal bearing is rusted to the driveshaft can be hard to remove- this can happen if bellows leak water
You basically end up pulling the rusty gimbal bearing out with the drive. Would try the 2x4 and and bet it pushes off with the driveThis is my concern at this point. Just wanted to make sure I didn't miss anything. Thanks!
You talking about the "O" ring?well, 2x4 worked like a charm. Don't see any signs of rust (I think) and the gimbal is silky smooth. There was a tiny puddle of gear lube (I think) in the bellows (pictured) but maybe that came from disassembly as the tank connector was dripping? There was also a little red/brown ring on the drive shaft end of the U-joints...Doesn't look like rust but some kind of assembly lube/grease maybe? Thoughts?
As mentioned would check alignment as possible cause of hard to remove.well, 2x4 worked like a charm. Don't see any signs of rust (I think) and the gimbal is silky smooth. There was a tiny puddle of gear lube (I think) in the bellows (pictured) but maybe that came from disassembly as the tank connector was dripping? There was also a little red/brown ring on the drive shaft end of the U-joints...Doesn't look like rust but some kind of assembly lube/grease maybe? Thoughts?
There is a seal behind gimbal bearing that people seldom replace. If drive is off, I'd pull bearing and replace seal. You probably need to realign shaft, anyway.well, 2x4 worked like a charm. Don't see any signs of rust (I think) and the gimbal is silky smooth. There was a tiny puddle of gear lube (I think) in the bellows (pictured) but maybe that came from disassembly as the tank connector was dripping? There was also a little red/brown ring on the drive shaft end of the U-joints...Doesn't look like rust but some kind of assembly lube/grease maybe? Thoughts?
The seal behind the gimbal bearing only keeps gimbal bearing grease out of bilge so it is not critical, would not take out a working gimbal bearing to replace it. It may not even be used anymore with the newer peralube (non greasable) gimbal bearingsThanks all. I will definitely be checking alignment in the spring before I re-install the outdrive. I realized the brown grease/dirt ring is actually around the coupler o-ring not the gimbal o-rings so I doubt the bellows are leaky, that and they are also only 3 years old. I will also check the parts diagrams for seals behind the gimbal.
Great information thank you. With my old boat, VP 5.0 GL-H I knew all the ins and outs. First winterization with a new boat, MPI and a Merc so it's been a rideThe seal behind the gimbal bearing only keeps gimbal bearing grease out of bilge so it is not critical, would not take out a working gimbal bearing to replace it. It may not even be used anymore with the newer peralube (non greasable) gimbal bearings
Ok dirt and grease ring from coupler makes sense on the newer ones there is a grease nipple on couplers that you can grease if you bump the engine so it faces up. I think merc was trying to get to or justify a 300hr service interval on drive removal coupler and u joint greasing vs annual.
Not much different. While its good to remove your drive and inspect I certainly don't every year. If you still have an original greasable gimbal and its smooth leave it alone and grease it. Grease coupler inside. I do engine oil, fuel filter and gear lube annually, grease points and my boats seem to last 25+ years.Great information thank you. With my old boat, VP 5.0 GL-H I knew all the ins and outs. First winterization with a new boat, MPI and a Merc so it's been a ride
and deck water spray dripping on shaft and traveling towards bearing. Trust me!The seal behind the gimbal bearing only keeps gimbal bearing grease out of bilge so it is not critical, would not take out a working gimbal bearing to replace it. It may not even be used anymore with the newer peralube (non greasable) gimbal bearings
