Neutral safety switch
Georgemk1
I have a 1972 40hp Johnson seahorse I'm working on my motor if I ohm the neutral safety switch out will it work
I put a new safty control switch on my 1972 40hp Johnson seahorse and the starter still wont turn over
jbcurt00
Moved your question to a topic of your own
please dont post to topics that have been inactive foe 90days or more. You posted to 2 topics from 2009, they are now closed
Honorary Supreme Mariner
That switch can be cleaned if it does not ground to the block when in neutral.-----Fact----There is only one wire that goes to that switch !---Yes, only one wire even though it looks like there might be 2 wires.
Crosbyman
selenoid needs 12 v
and a ground on the opposing side ​
to pull up . one is missing or both....
look for 12v on the post when turning the key to start if it does not pull up look for a missing ground on the opposing wire on the control post
selenoid may be OPEN internally
as a test apply 12v and a ground on the control posts if it works look for what is missing ... 12v or ground with an ohm/voltmeter
Explain post # 6 in some detail.----Starter turns on a bench or mounted on the motor ?----As it stands it means nothing to me.
Georgemk1
if I touch the starter side of the solenoid with a battery cable to the battery side the starter turns over
Maybe the battery cables on the motor are no good or you have a broken wire somewhere.------
Have an assistant hold the wire to safety switch to a good ground.---Does it crank now ?---If yes adjust the switch.
If this switch is mounted under the magneto plate it is meant to prevent cranking when throttle is open too far !!----Try with throttle pulled back.
I give up.----12 volts and wires are just to confusing to some folks.----This should be easy to solve !-----There is a cutout switch on this motor and it has to do with motor vacuum.---Prevents runaway in neutral !
Crosbyman
step 1.... do you or don't you see 12 volts arriving at the selenoid control post (from the start switch) when you turn the key to START... if yes proceed to step 2 if no... find out why by working back to the switch
step2- if you do get 12volts on the control post when you turn the key apply a ground manually on the other small control post post (not the big ones handling high amp bat +12 !!!!!!!) IF it fires the starter then you have a missing ground and you need to track it down why (bad wire, bad neutral switch, bad connection ground side of the neutral switch etc....)
http://www.aomci.org/forum/viewtopic.php?f=2&t=15012
go to the aomci site and look up the picture in the JAVALIN 35hp issue you will see an example of how the selenoid is wired..essentially waiting for 12v from the START switch but having a ground source with 2 protections... both are normally closed allowing the ground to reach the selenoid's 2nd small post
Either device would go OPEN in case the selenoid needs to be prevented from starting the starter. ....
if your start key 12v source reaches the selenoid post you are likely missing a ground condition due to broken wiring, or bad safety interruptors .
You need to get yourself a 15$ volt/ohm meter and learn how to use it if your are not familiar with one. It is not a hard issue to resolve and learning how to use the meter will in the long run save you hundreds of $$$
