Neutral Safety Switch
FreeBeeTony
In the process of disassembling my control box ( see prior post ), the neutral safety switch broke.<br /><br />Any ideas on where I can find one? The one DonS found is kinda $$$$.<br /><br />Any suggestions would be appreciated.........
Don S
Re: Neutral Safety Switch
Since the neutral safety switch is a safety device to keep you from starting the engine while it's in gear, and possibly hurting someone or something, I'm not going to tell you about hooking the two wires together that go to the switch. Because this would bypass the switch and you could start it in gear or out of gear or anytime for that matter.
FreeBeeTony
I hear ya Don........<br /><br />I know that could be a last resort.....would rather replace the switch.
I Wish the switch inside of My controller was the Same as yours.............<br /><br />I bypassed it Years ago...........<br /><br />I've got a Bzillion different old controllers in the wellhouse.......<br />Unfortunately, Don's photo doesn't Look familiar..........<br /><br />Have you still got my email address ???????<br />Send me some photos,+ I'll have a look around.........<br />If I've got 1, It's Yours.......
FreeBeeTony
thanks bondo........as soon as I get a chance I will take a few pics. And no......I reformatted my computer and deleted you email address......do you have mine?
You have mail......... ;)
Don S
Hey Bondo<br />When you get his picture, post it. Then we can make sure I had the right part number.
FreeBeeTony
You have mail too.........just a couple of pics of the switch put back together.........
Tony, the photos are Very Large...<br />And,<br />Very Blurry......<br /><br />Can't really See anything,+ I don't know how to resize them.....<br />The 1s you sent of the cooling system were extremely Clear.... These Aren't............<br /><br />Put a quarter next to it for a size reference.......<br /><br />Don,<br />I'm not good enough to post the pics here....<br />But, I just grabbed your address off the other thread..... I'll forward copies to you... <br />Or Tony could just send them to you.....
Don S
That'll work
Don S
Gottem Tony, but that isn't much help. Too blurry. Besides, send some clear pictures of the control, not just the switch. <br />Just have plenty of light and not so close.
Whatever Happen with this Issue, tony ???????<br /><br />I've got a Bunch of old controllers kicking around.........<br /><br />Maybe I can help you out again........... ;)
gspig
A switch is a switch. Can't any old waterproof switch be jiggered in?
FreeBeeTony
Hey guys, a friend of mine gave me a switch but I have to add the "arm" from my old switch.<br /><br />Don't worry...if I can't do it.......I'll be back!
FreeBeeTony
OK......I modified the switch my friend gave me.<br />Had to drill out the rivet holding the switch together to install the "arm", them installed a 2-56 screw in place of the rivet.<br /><br />Should work.......
